Those look a great deal larger than the 19mm you told me originally. I could have actually made them sized to fit otherwise. Glad they work.
I used regular PLA for my license plate bracket, switch panel, and some adapter rings for bar end mirrors on one of my motorcycles. The license plate mount is a little close to the exhaust and appears to have deformed a little bit, but it's still holding up. When I re-print it, I will try PETG.What material do you use for 3D printing these parts? I have two hobby-grade printers myself, but I only like how PLA prints so far. PETG was too stringy. I know that PLA isn't great for enduring outdoors environments, though. I have only tried doing ABS on my Hypercube once, but it's got a 12V bed that threw a runaway alarm before getting hot enough since it was taking so long, so I haven't tried since.
My buddy was going to mil this for me and asked if you have it on a DXF file?This is a coil cover for the LSJ engine. The split design was printed in PLA, whole design was SLS printed from Nylon PA12 and both bolted right up without issues. Including a couple different formats for the files to cater to everyone's needs for printing (stl, glb, obj, svg, mtl). Within the folder is a blank template (doesn't say "Goblin" in case you want to add your own letters), a split format of the "Goblin" so it can be 3D printed in most hobbyist printers (like my Ender 3 Pro) and a whole format of the "Goblin" if you want to have someone make this for you as well.View attachment 22404
I do not unfortunately. I’m still learning my way through solidworks so this was created in a free, elementary level online program and then exported from there. I’m probably going to remake this in solidworks so I can do the exports in different formats for stuff like this. Not everyone uses what I had exported inMy buddy was going to mil this for me and asked if you have it on a DXF file?
Ok thanks.I
Not sure of what part or area your referring to? Are you thinking of an airbox?Random thought:
I've seen a few people build intake shrouds. Have they proven effective?
Follow up question (if "yes" to the previous): Could a 3d printed shroud withstand the heat coming off the engine/supercharger? Has anyone tried?
Could you make me one if your printer is up and running again?I made a new cup holder that's meant to hold your phone too... it does not have the tunnels underneath because I plan on installing it ahead of the gear selector. I have not test this print yet, and it's made for a pretty beefy iPhone with case... use/print at your own discretion. I made a little bendy tab on the phone pocket to help keep it in.
@Goblin Graber you may be interested in this one too? It also uses the larger format already built into it in from the above feedback.
I’ve mainly stopped printing for other folks because businesses online can print and ship for cheaper than I can justify doing.Could you make me one if your printer is up and running again?
https://craftcloud3d.com/I’ve mainly stopped printing for other folks because businesses online can print and ship for cheaper than I can justify doing.
I’d go with the website @Ark :D uses, they appear to be decently priced and fast. (I forget the name of the company and I don’t want to search lol, @Ark :D this is where you come in)
