Go ahead and run your heat exchanger coolant lines. I wish I had before everything else as space gets tight.Yesterday did not go all that smoothly, I was trying to install the steering rack but it seemed that the holes for the bolts were welded improperly and there was not enough space to get it in. I ended up having to mallet the bolts in with quite a big of force which seemed to work. Here is the thread detailing that: https://dfkitcar.com/forum/index.php?threads/kit-welded-incorrectly.3927/
I was able to install the pedal box easily and now it is onto trimming the clutch pedal and I think I will trim the starter at the same time just to tackle that as well.
I just got word that there are still two donor harnesses in front of mine which is really unfortunate because I was told that Lonny can do one per week and that puts us at October 18th if it was completed immediately which Lonny has not been doing one per week because there were 4 in front of mine about a month ago.
This leads me to the question of exactly how far I can go without the wiring harness. I have seen that a bunch of people have put the engine in, could I do the suspension and other things like that. Just don't want to sit on the goblin for a couple weeks to wait for the harness.
I know this might be a difficult question to answer but is there anything specifically I should refrain from putting on?You could probably put the harness in last if you have to, just more work as you work around previously installed components. And you won't be able to do some of the start/run testing you might would do as you go through the build.
Provided you don't rivet on the tunnel cap, it's not even that much of a hassle to run the harness after assembly. A few screws and bolts here and there and the interior of the Goblin is stripped. I installed my harness without any sort of wrap to make troubleshooting any electrical issues easier several years ago, and was able to install split loom over all the wires this year without removing the harness from the car. You should be fine to proceed.The tunnel cover, seats and firewall(s) are the only thing I can think of that would be a pain with running the harness later. Everything else is pretty easy to get to.
Sounds good, I guess we will try to finish up the front end of stage 1 this weekend!Provided you don't rivet on the tunnel cap, it's not even that much of a hassle to run the harness after assembly. A few screws and bolts here and there and the interior of the Goblin is stripped. I installed my harness without any sort of wrap to make troubleshooting any electrical issues easier several years ago, and was able to install split loom over all the wires this year without removing the harness from the car. You should be fine to proceed.
And possibly tap out the threads of holes that got powder coated - that can take a while.might need to drill the powder coat out of a bunch of holes...
Is there a good kit to get for tapping. I just don't know what any of the sizes are for tapping out the holes.And possibly tap out the threads of holes that got powder coated - that can take a while.
Haha, planning ahead we did not. Just ran into the first thread we are going to need to tap.A good combination set of SAE and metric sizes up to 1/2 inch and 12mm would cover most any situation on a Goblin build. These can purchased from Amazon, Harbor Freight, or any of the big box stores that carry tools.
If you plan ahead and tape off or coat the inside threads with grease or silicon will help keep the threads cleaner during powder coating or painting.
7/16-20 > Welded Seatbelt NutsI have a list of taps I bought to clean threads of my chassis and suspension after powder coat laying around somewhere for forum reference. I'll find it and post up after I get home from work.
