Got the steering rack installed, EPS unit installed, brake and clutch lines installed, laid out the harness in the chassis and lastly cut the ignition switch down. Kick plate, front bulkhead and some other small pieces are hanging up to dry from paint. Need to dig out the steering column pieces to paint still.
Didn’t get the pedal box installed like I wanted due to the bulkhead needing to be painted. Was gonna wrap it, but figured since it was permanent that I’d paint it. So that will all be done tomorrow evening now.
List to do tomorrow (today?):
-install front bulkhead
-install steering shaft
-install pedal assembly
-install front radiator and hoses
-install manual brake setup (including proportioning valve)
