JeffsGoblin
You should've got that on video!
Good to know. So lowering the subframe and transmission will give me enough room to remove the engine. Thanks!I loosened the engine bolts, disconnected front and rear mounts and put straps around the engine and rear crossbar. Then removed the subframe and axles was able to work the trans free after that. Its takes a bit of muscle to lift it back in. next time I do it I will be wearing thicker pants and shirt.
I guess I could record this. Although I am already half way there.You should've got that on video!
Don't have to pull the engine to get to the slave (slave on trans)saving having to deal with the coolant. You will need to remove the subframe to get the trans off. I recall one bolt by the starter being difficult.Good to know. So lowering the subframe and transmission will give me enough room to remove the engine. Thanks!
LOL, well yes. It is sitting there, as I want to sell the stuff off it, but for the last year, I have been having so much fun building the Goblin that I haven't slowed down enough to start selling Cobalt stuff. I did sell the title & VIN to Jsix (John) so hopefully he could register his Goblin. That also means I don't have to pay taxes on the Cobalt, as I don't own it anymore... I own the parts.You still have the Cobalt shell??
Not sure if these will work they are replacement for the clutch pressure plate that I used much higher quality.Has anybody replaced these 3 shallow T30 head bolts with something better?
No wonder people strip these clutch slave bolts, they were hard to get out, and I half striped the heads too.
I don't see any reason to put back shallow headed bolts here. Maybe some normal height allan head cap bolts would work better.
Suggestions?
Thanks Lonny. I used my 1/2" hand held impact and a hammer to get them out, which probably did exactly what you said.I usually take an old 3/8 extension and place it against the head of the screw holding the extension straight with the screw. Then strike the extension with a hammer a few times. This crushes the aluminum behind the head of the screw a little which leaves the screw loose.
You may have to repeat this a few times.
That procedure is spelled out in the SAAB transmission repair manual.I usually take an old 3/8 extension and place it against the head of the screw holding the extension straight with the screw. Then strike the extension with a hammer a few times. This crushes the aluminum behind the head of the screw a little which leaves the screw loose.
Make sure the thicker headed bolt does not restrict slave cylinder from moving all the way to the bottom.Thanks Lonny. I used my 1/2" hand held impact and a hammer to get them out, which probably did exactly what you said.
At least I got them out! I don't want to put them back in - even new ones, as they are poorly engineered for the job, and I can't see any reason why Chevy used thin headed shallow T30 bolts.
SAAB asked me if they could use my technique in their manual and I said "Sure, go ahead".That procedure is spelled out in the SAAB transmission repair manual.
Brad
That was my concern too, but it looks like there is room for a normal head cap bolt.Make sure the thicker headed bolt does not restrict slave cylinder from moving all the way to the bottom.
Brad
