Ross, you will have your car so clean and spotless you won't want to take it out of the garage!
That paint job....Trying to find torque values for bolts...
This part supports the intercooler and intake, but I don't know its correct name, and can't find the torque values.
Same for these parts... looking for torque values.
Hi Ross,I fixed these a while ago, but am adding the $8 intercooler pump fix, and the fix to the radiator fan, to my build log.
I finally figured out how the fans work on my 2006 Cobalt SS. I was able to reduce the temperature that the fan turns on at, which was pretty high (223F on, 217F off) on the factory chevy settings. This is HP Tuners, VCM Editor software:
Fan 1 is my engine coolant fan, (purple lines), it switches on (1) when the engine temp is higher than ~205F (which is "Fan Desired" = 22).
Fan 1 switches off (0) when the engine temp is lower than ~199F (which is "Fan Desired" = 12).
The blue lines are for reading the AC system vapor pressure sensor, and then turning on/off Fan 2 according to the tables above.
Or in a Goblin, since we don't use the AC system, you could put a different 5V sensor instead of the AC system vapor pressure sensor. Maybe a 5V oil pressure sensor. Then the PCM would read the new oil pressure sensor, and report on it on the AC pressure PID. I'm not sure what PID that is, but I know HP Tuners can see and report on it. Wikipedia doesn't list the AC Pressure sensor... unless it is one of the Evap system pressures:
Maybe the Evap vapor pressure sensor could be repurposed too?
PIDs
(hex)PID
(Dec)Data bytes returned Description Min value Min value Units Formula[a] 05 5 1 Engine coolant temperature -40 215 °C ![]()
32 50 2 Evap. System Vapor Pressure -8,192 8191.75 Pa (AB is two's complement signed)[3]![]()
53 83 2 Absolute Evap system Vapor Pressure 0 327.675 kPa ![]()
54 84 2 Evap system vapor pressure -32,768 32,767 Pa (AB is two's complement signed)[3]![]()
View attachment 39253 View attachment 39254
View attachment 39255View attachment 39256
View attachment 39257 View attachment 39259
Interesting, if I see that correctly, it is not possible to run AC Input and Fan 2 output completely independent from Fan 1. If Fan 2 is requested and Fan 1 is off, then Fan 1 would switch on. I have to study the diagrams a bit better and do some more testing.I did figure out the HP Tuners logic for the fans.
The LSJ has fan high and fan low speeds. Fan low speed puts both fans in series, so that they get 6V each. So, yes they both come on at once.
In fan high mode, both fans are at 12V, so potentially they could be individually controlled.
The motor going in is one I bought 3 years ago, and have never driven. It got a cam chain, sprockets, guides, & tensioner, fresh paint, and the next step is to see if it is a good healthy stock LSJ engine.Is this the motor with the rods, pistons, and cams?
A lot of builders don’t understand this, it’s even worse in the motorcycle world. The car is more capable than the driver. More power isn’t going to help you. As you build skills and dial in the car, then you add power. It all goes hand in hand.I would like a goblin that I find fun. Over time, as my driving ability and comfort level increase, I want more power for more fun.
