Towerdog
I finally had a little time this afternoon to mess with my car. I am having some major electrical problems!
Lighting is all perfect but I have no power to the fuel pump, starter relay fuse, injectors, butterfly... I have checked every fuse, connection, and pins in the plugs. Display will read the temp 0Miles, then power steering (if red wire is plugged in at fuse box) and then low coolant (none in there).
I can hear the injectors click if I touch their fuse with the test light.
OBD II scanner reads error, like its not hooked up or the key is off when it is. Worked fine before it was stripped.
Any help or suggestions would be appreciated.
