EbayThat S#cks, but my question is where did you get the graphic from? Would like to see what else they have?
You just gave me hope!When I had to problem of two o-rings in the elbow, it showed no signs of leaking other than the puddle in the floor.
Im hoping and believing the clutch pipe seal was not installed on the pipe itself there for not sealing completely. I have installed a new elbow/distribution block and made sure the seal was seated properly..... Now I need to run to town and get a cheap 9mm wrench so I can bend it to be able to get it in there.... PITA!Any chance you blew out the slave cylinder by over extending? About the only spots to leak are the elbow and the slave.
Sounds like you need to work on a hood hinge system. Believe @Torchandregdoc put together something workable using donor hinges(?).The "Goblin clutch bleeder wrench" made that process so much easier.. Got them rebled and it seems to be holding pressure with no drips. We will let it sit overnight and see if there is any fluid on the floor.
Found a way to add brake fluid w/o taking the hood off.
Well my hood is 1" higher in the rear due to the fact that no matter how much pulling, pushing, and cussing I did the bolts would not line up.Sounds like you need to work on a hood hinge system. Believe @Torchandregdoc put together something workable using donor hinges(?).
CongratsWell I am officially official! Got insurance approval yesterday and plated this morning. 9 minutes in and out of the BMV, Thats got to be some kind of a record. The down side heavy rain and thunderstorms all day today.
