If this is the case something else is very wrong. Other than the reservoir the brakes have nothing to do with the clutch. Once your brakes are bleed the amount of fluid that is used to actuate the brakes is very little. I highly doubt you are removing any fluid out of your brake lines bleeding the clutch. But you have been trying every single way to bleed a hydraulic system known to man, so who knows...
I was looking for pictures of your brake and clutch line set up at the front of the car, and ran across this picture. Are you sure your clutch pedal is fully extending to the released position? Chad had issues with his brake pedal not fully releasing and causing bleeding issues on his brakes.
This has been the hardest thing to do so far! It has curled in making it about 2" too narrow in the back..... a lot of clamps were involved. Is this the fiberglass footwell cover option? I purchased it with my kit, but didn't realize it was basically a second hood in size.
dfkitcar.com
