Just received confirmation that I can go pick up my kit from the shipping terminal on tuesday!
On a side note... Part 14 of the videos at the 6:34 time mark. I can't find that connector thats on the steering column. Can someone post a photo for me or tell me what its used for?
I'm thinking if you have an manual transmission, you may not have that connector. I have a manual and I don't remember that connector either. I only remember two, one for the VATS (black plastic ring around the key) and the other one for the actual ignition. Sorry I'm not much more help on that one.
I think it is the Ignition Lock Cylinder Control Solenoid. We do have an automatic transmission.
D
Thanks for the help guys have a MT and i have that connector on the harness, but not the connector on the steering column. I'll just ignore it for now.
D
Another dumb question of the day... the bottom connector of the two shown, is it used in a manual transmission? Either i lost it or it's not used. Thanks all
D
I have been slacking on the updates, but here are some. My NRG seats came in with the 5 point harness. I'm almost done with the wiring harness. I ordered "Intense Blue" powder from prismatic powders. And i found a trailer to borrow... one bolt is still stuck in the subframe that I'm still trying to get out.
D
I just picked up my kit and opened it.
D
I have seats with seat sliders. I think i need to have a bracket welded on before taking it in to get powder. In the mean time I'm doing some engine work and prepping little parts for paint/powder coat.
Yeah, as hard as it is, don't be in a hurry to get it powdered. Try to think of all of the things you need to add/modify before you seal it up.
Any suggestions you may have?
Bars for seat sliders.
Cut the tunnel cover
Extra tabs for side panel mounting. I only added 1 on each side. I am going to try 3m VHB tape to hold my sides on with only 1 or 2 rivets
Extra floor supports. That aluminum floor is thin and will not hurt to have an extra bar or two.
D
Thanks for the suggestions. I'll try to get these added this weekend.
