D
Note to self, don't get cars grim Wyoming. This car was rusted to ****. I have to buy new rear hubs and sway bar links. I got everything off except the engine and transmission. I'm hoping to get a shop crane today or tomorrow.
Not surprising. My wheel hubs were just to the point that I didn't want to use them. Ended up buying new ones and converted the wheels to 4-bolt pattern. Worked out in the end. You won't need the sway bar links. I kept them thinking I would want the sway bar, heck even powder coated it, but never installed it.
D
Yea, i was goingto use a friends, then i saw this on offer up. So i ended up buying this... i was looking at harbor freight also. One question... did you buy chain to hook it up to your engine?
DanPerryy
The engine and trans are light enough that a chain works just fine. I did have a bit of a trouble with one of the camshaft sensors getting in the way of the chain and breaking it. BTW - I found the sensors from China for like $7 each. Bought a couple they work fine.
D
Nice! Thanks for the info. I may have to just stop by home depot on the way home and pick me up a piece of chain.
D
Do the yellow pieces just pop out for the manual transmission cables?
D
Got the engine dropped... now need to lift the front of the car high enough to roll the engine out. Gotta get a new starter because it was rusted to ****. Also one of the bolts are stuck into the lower control arm and sub frame.
Not many of the starters make it out without falling apart. I replaced mine because the plastic around the terminals fell apart.
