CaptFrank2001
Well minor setback last night. While taking the donor off of the "borrowed" trailer I fell through the rotten wood. Banged up my right knee pretty good but luckily I did not break anything. It's sore but will be OK in a few days.
CaptFrank2001
First Surprise - Once I got the intake air cleaner removed to de-grease the engine look what I found. A whole lot of JB Weld. Not sure yet but I am guessing there was a coolant leak that was "Jury Rigged". I guess next step before I defuel the car is to pull this crap off and see what I find. I did plug in an OBD2 reader and found no codes.
CaptFrank2001
Well Surprise, Surprise (sorry Gomer Pyle) I ran the engine up to operating temperature and then scraped all this JB Weld off. Started the engine and nothing. NO leaks, no issues. What it was on there for is beyond me. Before & after pictures. This engine runs so well I may not do anything to it. Purrs like a kitten, smooth and quiet.
WYGoblin
I had a similar thing like that on my valve cover. The only thing I found was the previous owner tried to "glue" the check valve going into the intake and it dripped down on the valve cover.
Glad you didn't find any problem must be a relief
CaptFrank2001
I was trying to determine if the donor had the original engine. Thanks to Adam at DF who showed me where to look on the engine (near the starter) for the partial VIN. Finally found it and it's a match. A little hard to make out but it's 16765 which is the middle five numbers from the vehicle VIN.
