- JBINTX Goblin Guru
So when I was disassembling the donor, the video said to remove the little sensors on the pedals to make it easier to paint them. DO NOT TRY TO REMOVE THEM!!!!!! The screws are very little and very soft. Just tape them up to paint. I twisted one off and struggled to remove it from the plastic sensor. They are cheap, so I replaced it with a new one. Well, the new sensor was my problem above. Today, I worked to get the broken screw out of the old one, reinstalled it and the issue went away. Not sure why the new sensor was constantly sending a signal.I temporarily hooked up my rear lights. I am getting 12v constant on the green / yellow wires. When I turn on the blinker, they go into the correct blink mode. When I reset the blinker, they go off for a moment, and then back full on. The side mirror signals seem to blink correctly with the blinker engaged. Brake signal issue -I assume? I do not have any brake fluid in the system yet. Is the brake fluid reservoir sensor maybe sending a signal here? There does not seem to be any adjustment on the brake signal sensor. I disconnected the green / yellow wires both sides and running lights are on properly then and blinkers work correctly.
I am using the DF rear lights. Here are my connections at rear:
Harness Maxxima light
black (grnd)---------------both white wires from plug 1 and plug 2 (plug 1 is stop, tail, turn - plug 2 is reverse)
brown (run lt.)-------------black wire plug 1
green/yellow (turn R/L)---red wire plug 1
lt. green (backup)---------red wire plug 2
Anyone see the issue here?
