- ctuinstra Goblin Guru
The fuel pump will only prime with the key in the "On" position for a few seconds. I will run longer when the engine is cranking or if it is/was in a running condition.Fuel pump primes. It ran for roughly 2 hours this weekend when trying to do the key relearn cycles. Would a bad fuel pump cause it to not crank over? Like no audible sounds when trying to start.
No, a bad fuel pump won't cause it to not crank over but I was suggesting that for the engine dying on you.
