HHR Compatibility
The Chevrolet HHR shares many components with the Cobalt, but it is not fully compatible as a donor for the Goblin V1. There are important differences in parts such as the fuel pump, pedal assembly, and gauge cluster that prevent it from being a direct substitute. Using an HHR as a donor will require additional modification and sourcing of Cobalt parts to complete the build.
One builder successfully completed a Goblin using an HHR SS along with a Cobalt donor, using as many parts as possible from the HHR and filling the gaps with Cobalt parts. If you are considering an HHR donor and want to understand what is involved, his build thread provides useful insight into the process:
Jim McDonald // Extended Track // ‘09 HHR SS/TC Automatic
While an HHR can be used as a supplemental parts vehicle, the most practical and cost-effective choice is still a complete Cobalt donor.
