JeffsGoblin
- JeffsGoblin Goblin Guru
Do some research on painting and powder coating manifolds and SCs. Some say it will create / hold heat and that would be bad for performance.
Hmm. Thanks I'll look into that.Do some research on painting and powder coating manifolds and SCs. Some say it will create / hold heat and that would be bad for performance.
I doubt very highly the injectors have anything to do with it. There is no place for the ECM to even “know” what injectors are in it. The only thing is just the flow rate. There is something wrong with it. ZZP should make it work for you.I have an Engine disabled code with my new pcm from zzp but otherwise it tries to start with the old one in, i think it doesnt due to the 60# injectors anyone else have trouble with this?
I noticed you had the ZZP kit. Did you already send you computer to them? Wonder if it's the tune.No it turns over and gets fuell but doesn't fully start I have many hours into the issue with a freind last fall, and have not messed with it in months.
I wonder if you could find someone near you that would let you put your ECM in their car long enough to see if it will run. If not you could ship it to us and we can test it.
This will at least eliminate one possibility.
If you think it is your wiring harness give me a call and we will see if we can find a solution.
214-334-0232
