V1 Dre city Goblin build - 06 LS Donor
D
Pulled the whole wiring harness out of the car... this kind a pain. I can't get the car to start and my axle seals won't go in.
If you were closer, I'd stop by to help you out.
There is a tool to help install the axle seals. I know nuker has one. We replaced our seals but didn't use the tool. I had a large round short section of pipe that fit it very well. You have to hit them evenly all the way around. You don't want them starting crooked, it will deform them and cause them to leak.
Good luck!
  • Like
Reactions: Dre
D
Thanks. I reviewed it and because mine is a 2006 manual, there are some discrepancies. Lots of it were the same and it seemed all its about the same
D
Laying on the floor. Easier to work with.
The single blue wire is for your parking brake.
Do you have all five big multi connectors in your fuse box? There is a white multi connector that is for your headlights, it had a ground wire that must be hooked up.
Does your fuel pump ever cycle when you turn on the key?
Does your throttle body's butterfly move when you press the accelerator pedal?
Does the instrument panel lights go off when you turn the key to the start position?
I have all the headlight and blinker wires bundled up, you want me to pull one of the ground wires from that and ground it?
The big ground from the white fuse box plug must be grounded.
  • Like
Reactions: Dre
