Your lower control arms are on the wrong side and upside down.Thanks, That is where I did put it.
In the picture I have also flipped the mounting bolts.
See the pic here:
Jason in Texas - ext. track - 09 SS/TC
Dc. What tires are you running? I’m a firm believer that anything over 200tw is an accident waiting to happen. I use the Toyo rzzr’s. And although I can get to slide and spin, it’s very controllable. I’m running 13psi rear and 11 front at autocross. The rear sway bar does help a good bit (Jason...dfkitcar.com
While this is the prescribed orientation of the lower control arm, I think that it is worth noting that some builders (@ManDan1957's car comes to mind) installed them upside down/reversed to gain additional ground clearance.Close. The lower control arm is upside down. The shock mount should be below the lower control arm.
Is it just an optical illusion or are the rod end brackets - the black angled brackets at the top and bottom of the aluminum upright the a-arm rod ends attached to - in the wrong locations? If your kit came with both thick and thin (relatively), the thick brackets go on the bottom and thinner brackets go on top. If all 4 brackets are the same thickness, please disregard my poor eyesight.I think this correct now?
Got another pic of your front suspension from the front or behind?Technically they were mounted correctly in the aluminum piece, it was the aluminum piece that was upside down, it belonged on the other side of the car.
Some times I think I could screw up a free lunch. Hopefully if nothing else some future Goblin builder will learn from my mistakes.
