comegetjoe
- comegetjoe Goblin Guru
I'm sure I'll find a home for them at some point.
Only other blue connectors I have are for the evap solenoid but mine has a blue tab and a red body. My other is for the boost solinoid but I’m not sure if your would have that or not with a turbo. My AC compressor connector was cut out when I gutted the compressor but it didn’t look like that at all.These two guys are already plugged in. The white one is tagged "speed sensor" and the other I'm pretty sure is the reverse lights.
View attachment 47532View attachment 47533
I think the green one is F35 speed sensor. The colors of the wires leading to them would help! Speed sensor is a purple wire and a yellow wire. There is a red connector on the fuel purge valve that may have gotten plugged in elsewhere. It would hide a connector!Wham bam efffin plan
Done list today
-plate installed, measurements taken for standoff for fusebox, almost permanently temporarily mounted, y'all know how that goes, on-off-on-off
-clutch line installed, had to go fishin' for one of those little clips to hold the line in. Did you know there is at least 3 different sizes/lengths?
-radiator video completed, is the radiator support bolt acceptable as a ground or is it necessary to drill into the frame again for another ground?
-Heat exchanger wired in
-coolant hose at the T put on
-fusebox trimmed
-final coolant connection on the passenger side at the head completed
And what may those last two connectors be? I have the coolant tank tagged, so that's not it.View attachment 47525
View attachment 47521View attachment 47522View attachment 47523View attachment 47524
I second that. I took a look at mine and those plugs look identical to those two locations.
Talk to me. Whatchu mean?Gotta route that one under the frame. Looks out of place just sticking out Like that.
Yes that one. Aesthetically speaking, it would look better under the crossbar. Maybe route it straight and next to the fuse box. Then turn it to the intercooler areaTalk to me. Whatchu mean?
1st pic, clear line, drivers side, over the cross bar? That gets cut short and goes to the drivers side of the intercooler.
sorry. iPad markup sucks, but here you go
