PARTS UPDATE!
So today was an exciting day! I got the solid engine mounts installed and the new shifter upgrade as well. Here are my thoughts on both.
Solid Engine Mounts
Installing the mount that goes under the exhaust was a breeze (I removed the muffler for easy access), but the mount under the engine proved to be a little more difficult. The bracket on my subframe may have been slightly bent or over tightened previously. To get it in, I bolted up the bracket to the engine, but it wasn't lined up quite right with the subframe. After some convincing with a bottle jack I managed to get it on place well enough to run a bolt through.
The performance seemed good and the car felt very planted. I didn't have a huge problem with wheel hop before, but I certainly won't have any issues now! There might be a small increase in vibration, but not enough that I can say for sure.
Shifter Upgrade
All I can say is WOW! What a difference. My previous shifter had a lot of slop. I was pretty use to the quirks of my set up, and I wasn't disappointed in the performance, but I did not like how it looked. The old shifter and plastic just looked out of place on a shiny, beautiful goblin.
I like the set up of the new tunnel cover more than the old design. It was easier to position and my terrible electrical tape job near the front of the car doesn't have clearance issues any more! You will need to drill extra holes for rivets, but you can dry fit everything and get the holes drilled in a matter of minutes.
The shifter itself is very responsive and easy to use. I still have some fine tuning to do, but the car is easier to drive than before, and I haven't made any adjustments since the original set up.
You end up with some extra length on the shift cables which I appreciated. It allows for a nice, fluid arch towards the transmission. You kind of end up with a "question mark" shape. Along with the new engine mounts, I'm happier with my cable routing and I think it will reduce friction for more crisp shifting!
The only point of confusion I have is with the lock out. I don't really understand the benefits of it, so if someone could explain that to me I'd appreciate it! I removed the ball from my original shifter, so I never had the lock out anyway. Is it to help prevent you from shifting from 5th to reverse when downshifting from 5th to 4th? Either way, I don't currently have the position of the shifter set up in such a way the lock out works, so it may get removed.
Conclusion
Overall I'm thrilled with how the car turned out! With the help of you guys and DF Goblin, these cars are just getting better and better. I love having the opportunity to be a part of this community and I look forward to the next upgrade!
