neodied
- neodied Well-Known Member
New to-do list:
- Finalize dual gauge pod design tweaks (adjust insert pieces for AEM gauge stud spacing and OEM boost gauge depth)
- Check cylinder compression
- Tuning: MAF
- Repaint the muffler (starting to flake off, I don't think I followed the instructions for curing the paint)
- Add screen to the hood front opening
- Find a thinner seat cushion to drop my vertical position a bit
Cold season projects:
- Key on switched power block (heat exchanger fan, wideband O2 sensor, USB power, etc)
- New clutch and flywheel
- Clean PCV valve
- Injectors stock -> 60lb Bosch (not Siemens), pulley stock -> 2.8", then tune (start from Ghostknife's tune)
--- https://www.dfkitcar.com/forum/index.php?threads/zzp-black-friday-deals.3218/
--- https://fuelinjectorconnection.com/.../650cc-bosch-split-spray-for-multivalve-heads
--- https://www.cobaltss.net/forums/tuning-131/injector-basics-lsj-300942/
- Side panels
- Maybe swap the OEM boost gauge for an AEM gauge to match the wideband AFR gauge
- Tuning: MAF
- Clean PCV valve
- Side panels
