V1 Nukers City Goblin - 2009 SS/TC number 2 build
Zoom Zoom
Picture 1 on intake hooks up like this, You need for that big Z54 turbo to work
TheNuker
What is that piece on the intake called, and what does it do? And where does it go after it comes out? So I see the nipple on the intake manifold goes into that black box, which I have, then it goes out of the black box into some solenoid or something, then out to where?
Thanks,
Nuker-
Zoom Zoom
Thanks,
Nuker-
To the turbo, the yellow looking connection
TheNuker
But it looks like that hose is attaching to some kind of part on the intake, What is that part and what does it do? I'm assuming after that part in the intake top that it connects to the hose goes to the part on the turbo thats tanish plastic color with nipple pointing towards passenger side?
Nuker-
Ugh this never freaking ends i'm always missing parts.
N
Nuker-
Here’s what I know:
The part on the top of the intake is the turbo bypass solenoid. The tannish plastic part on the turbo is the bypass valve. The black tank is a vacuum reservoir.
Other model cars that use the LNF don’t employ the vacuum tank, the bypass solenoid tube that goes to your vacuum tank is connected directly to the intake.
So the solenoid switches from the intake (vacuum when throttle is closed) to atmospheric pressure (or nearly atmospheric) to actuate the bypass valve.
Here’s what I don’t know:
When does the solenoid actuate the turbo bypass?
Why does it actuate the bypass?
I’ve searched other forums and can’t find much info except that many have deleted the vacuum tank because it’s prone to leaks.
The LNF crate engine I purchased does not have the vacuum tank.
Here’s how it’s connected on my engine:
Most turbos have an electronic boost regulator (probably built into the Cobalt ECU) while others just have a limiting spring.
A boost controller controls the amount of pressure going to the wastegate.
N
The turbo bypass valve is a separate system from the waste gate and boost controller. When open, the valve bypasses the compressor section of the turbo. Possibly so that it spins up faster? Or spin down faster?
TheNuker
Here’s what I know:
So I'm guessing the "To DF supplied fitting" means that it goes to the intake brass barb?
Thanks guys!
Nuker-
N
Where does the hose to the Df supplied fitting go in your picture?
nuker-
Thanks guys!
Nuker-
To be honest, I haven’t installed the intake piping yet, so I haven’t identified exactly which brass barb it connects to. I think I read where the valve cover nipple fits on the MAF tube and the tube in question fits on the MAP tube.
TheNuker
Going to redo all of that piping tuesday, it looks like **** LOL.
On another note, What is the thread size on the brass nipple on the DF supplied LNF lower charge pipe that the TMAP goes into?
Thanks,
Nuker-
