- Fred Member
Any ideas the car was running driving perfectly due to a licensing issue its been sitting for two months. State of Co. tells me i have to take for another inspection !!
long story.
The car was on a battery tender while stored probably have nine hours into ten min key relearn light stays solid I've unhooked battery BCM and ECM checked wiring and found no issues can jump the start relay and will start while cranking. talked with my GM dealer he said i need a $380.00 GM reprogram ? would like to remove or by pass this completely if could will take it to GM if needed just thought I would reach out to the Goblin community for some input.
The car is a blast to drive almost have the en
long story.
