- Gtstorey Goblin Guru
After rereading you are correct . When he said filter, my mind went to the sock on the later models. Still need to be careful with fuel line from ace hardware, since it might not be rated for fuel injection pressures, only carburetor pressure.I think he’s talking about external lines not the internal ones. If they are internal, then yes, must be submersible and capable of holding over 60psi. If external, then it just needs to be fuel injection hose capable of over 60psi. I used Gates 4219BF 3/8” hose.
4219BF Barricade™ GreenShield™ Fuel Hose | Gates Corporation
Before you start your engines, equip them with Gates fuel hoses. We’ve engineered our fuel line hoses at the cutting-edge of fuel-efficient, environmentally-safe design, so your engine will perform with superior power.www.gates.com
