D
Some photos
D
I have the tan twisted wires going from the obd2 to the power steering. And just a ground and power coming from the power steering
The power steering connector should actually have two sets of data wires. The first set tan/black which comes from your OBD-II connector. The outgoing set is brown/white and brown which runs from the power steering connector to the BCM. I believe this is the only part of the circuit where wire colors go different.
I see the wires in your picture, but I can't tell where they go. Something to check as most people just focus on the tan/black wiring.
D
Thanks man. Il check that when i get home, if it looks good, then I'll start checking for continuity. When i connect the battery, i hear a relay click.
On a side note, i have the large positive battery wire going from the battery to the starter and i have the starter wire going from the starter to the fuse box.
D
Also does anyone have the same manual transmission i have. Im trying to figure out the piece that is missing that holds the clutch cable bracket on.
jennam
Where are these used at? I know, bad photo.
Correct, those are the front fender mounts.
Anyone have a photo of this setup?
I have that same setup. The o-ring end goes into the master cylinder and that curvy piece is a spring to hold the other pieces down. I’ll try to get you a good picture of it tomorrow.
I’ll also get you a pic of the shifter cable mounts.
  • Like
Reactions: Dre
jennam
I’m going to hold off on the shifter picture, mine’s not working right and I don’t want to give you one of my problems...
  • Like
Reactions: Dre
