V1 Nukers City Goblin - 2009 SS/TC number 2 build
TheNuker
#2 looks like the AC refrigerant pressure sensor
#3 looks like the AC compressor clutch
#4 looks like an O2 sensor.
I can't see the pins enough on #7 to compare them to electrical connectors list.
I think your right for sure about the second O2 sensor plug, I just noticed that the upstream and downstream have different plugs. I just ordered the upstream one now. Thank you!
So far found this
#1.1 Red/blue EVAP not needed on goblin
#1.2 all black with metal clip EVAP not needed on goblin
#2 AC refrigerant pressure switch (basing these off locaiton I think your right jamesm)
#3 AC compressor clutch (basing these off locaiton I think your right jamesm)
#4 Upstream O2 sensor - sensor missing ordered.
#5 Ambient temp sensor- missing sensor ordered
#6 Blue/Gray - Backup sensor - sensor ordered was not included on new transmission.
Just missing #7 now. thank you everyone so far.
Nuker-
#7 looks like one of the 5-pin connectors that is unfortunately the same design for the MAF and the sub-harnesses for both the coil packs and the injectors. If that's the case then you can either narrow it down by process of elimination or checking wire colors.
TheNuker
TheNuker
That looks like the MAP sensor connector.
Hmmm I think I have the 2 map sensors plugged in right just verified they are different plugs then this one.
What attaches to this tube that DF provides for the lower TMAP sensor there is another port kinda like what a brass nipple would screw into.
jennam
I scanned back through my connector list and compared the wire colors. That actually looks to be the cam position sensor connector.
21963
21964
Zoom Zoom
One of the GM STAGE 1 Sensors hook to that one and the other one here
and then the MAP sensors here
TheNuker
Yep you're right I feel stupid LOL I thought I had them both plugged in and could not see the front one. Yeah sure enough.... That means I have no outstanding plugs or sensors!
Thanks everyone. Hoping to start this sucker this weekend.
Nuker-
TheNuker
Yep, I'll have 2 12" fans sucking air through, Eventually I'll probably make a box with scoops on the sides closing it in from the turbo/exhaust. TBH with the dead spot behind the seats I don't see it being much worse. I just never liked the big ugly IC up on top on the bars.
Nuker-
