V1 Whidbey Goblin, track chassis for the streets. 05 SS donor.
Whidbey Goblin
I pulled this seal off the old CVs. There is only one though, is there supposed to be one for each side?
Whidbey Goblin
I had DF kit car do my wiring harness. This plug comes out very near the wires for my fuel pump and the plug that goes to my coolant tank. Not sure where this one goes…
It is so you can tell how hot or cold it is outside when you are driving in your air conditioned or heated Goblin.
I don't know if it is needed, but I doubt it.
Whidbey Goblin
Getting pretty darn close! I’m going to have to build myself a pretty large paint booth before I build my next one.
Ground in the dash harness? Believe there is one connected at the pedal box. Maybe too much coating to make a good connection. Try jumping that Ground with a wire to the battery Ground only 2 feet away?
Whidbey Goblin
All of my grounds go to the same place on the peddle brace. Everything else seems to be grounded good, I took care to make sure they were clean and bare. I will make a jumper and try though.
Whidbey Goblin
Doesn’t seem to be a ground issue. Checked all the fuses. This diagram doesn’t match even close. Starting to worry a little.
