V1 Whidbey Goblin, track chassis for the streets. 05 SS donor.
Whidbey Goblin
I would finish the Goblin and as long as the oil leak is not too bad drive it for a while. When the engine gets up to temperature a few times the seals will soften and conform better which might solve the leak problem. If it doesn't at least you got to drive enough to test the clutch and know if anything other problems need to be addressed while you are in there.
I was wondering if that would be the smart move. Thanks for confirming that, that’s exactly what I’ll do.
Whidbey Goblin
Finally pulled the wheels out to get a sneak preview while I wait for parts.
Whidbey Goblin
These are the little retaining clips for the rear control arms. (originally front control arms in the donor) Are they necessary? Did everybody use them or did most people pitch them?
Whidbey Goblin
So I received most of the rest of my parts. Among them are some ball joints that are labeled “tie rod end goblin front”. Am I supposed to remove the existing tie rod ends and put these in their place?
Whidbey Goblin
This just doesn’t seem right. It looks like with a little bit more travel it’s just going to bind at this heim joint. I’m pretty sure I assembled everything correctly, passenger side is worse than the driver side. Did I get a bad set of upper arms?
That looks good to me. Remove a shock/strut bolt, so you can move the suspension up and down by hand. Check the maximum height, check for binding, check it is smooth.
The thicker shaft diameter is a SS/TC shaft, the thinner one is most likely a SS/SC shaft. Since the Goblin is so light, the difference in shaft diameter will likely not create any torque difference issues (the thinner shaft will have more rotational flex).
Just me, but I would use the thinner one on the driver's side to (theoretically) be closer to the flex of the intermediate shaft and passenger side shaft.
